[SOLVED] Weird scanline flicker on Benq monitor ?
theroot69
5
Happy New Year!
Does the culprit panel exhibit the same issue on a donor system(not the one it was plugged into initially)? If so then perhaps try and replace the display input cable and see if the issue persists. If the issue is there after a donor system hook up + replacement known working display cable, then the issue is with your panel.
it looks like every 2nd line of pixels below the white line is showing the right pixel line, while every other is confused and doesn't know which line to display and just flickers between lines way below what it's actually supposed to show
UPDATE: Monitor is bad, took it to 2 repair shops they said i'm better off buying a new one.
