Greetings,
my computer is 3 years old right now, and it was a really good one by 3 years ago standards.
Since the tower case is let's say "homemade" to not be too precise, the airflow kinda sucks; i had a lot of temperature issues with cpu and motherboard; then i got water cooling for my cpu with the radiator placed outside so it wouldn't depend on the internal case temperature; and thanks for the space saved compared to an internal huge air cooler i could add a fan that points directly to my motherboard heat sink.
Since i did that my computer works flawlessly with intense and demanding games *during winter*… and only during winter with open room windows.
During summer, it's still a miracle if i can run a game with minimum settings for 1 hour, and that's AFTER i added the water cooling.
The weird thing is, i'd expect my cpu to rise in temperature gradually, hit the 75° limit i've set and then shut down my computer as planned.
However, i tried playing with Open Hardware Monitor (from now OHM) on the side, checking constantly motherboard, cpu and gpu temperatures. Since i added that fan in front of motherboard's heat sink it stopped being a problem (before it was the mb that reached critical temperatures first), now it doesnt get over 60°. The gpu has 2 fans of which only one works automatically, and the other one is supposed to self-start when gpu gets too hot, but apparently it self starts too late, because many times i've seen gpu temp go up, second fan starting right when pc suddenly shut down. But that's easily solved manually setting gpu fans to 100%; doing that gpu doesn't get past 65-70°.
Now to the problem: the cpu. It seems to act weirdly; while mb and gpu gradually increase their temps and then stabilize, cpu suddenly jumps from 22-30° idle (even during summer which i think is awesome temperature, considered it's practically air temperature here) to 60+. Only a couple times i could see the reading in OHM get to 80+ one instant before the pc shut down. (OHM updates readings every second). And it jumped to 80+ totally suddenly from around 60°; which made me suppose all other times my pc shut down with no apparent over 75° reading it was because the cpu suddenly jumped to 80+ and the pc shut down before i could manage to see the reading.
But if i see the temperature reaching 73-74 and i instantly close the game/program which is draining resources in literally 1 or 2 seconds, no more, it's back again to 22-30°.
So it cools incredibly fast to incredibly low temps, but it utterly fails at keeping stable temperature on stress.
Running any stress tool my computer shuts down, no matter what. Even running memtest it shuts down, and it's not because of the memory blocks (i've checked them individually in someone else's computer).
Could be the psu? I highly doubt it, since it wouldn't explain why it doesn't have problem in winter at opened windows.
What can be the issue?
________________________________________
Motherboard: CROSSHAIR V FORMULA-Z
CPU: AMD FX(tm)-9590 Eight-Core Processor (8CPUs), ~4.7GHz
Memory: 4x 4GB Trident-X
GPU: AMD Radeon 7800 Series (too lazy to check the exact version, shouldnt matter though xD)
Water cooling:
CPU only,
Pump: Aqua Stream XT
Radiator: EK Water Blocks EK-CoolStream PE 360
Water cooling:
CPU only,
