Weird thing going on...
Oct 23, 2016
19
To clarify everything before stating my problem, I must say that I have a A10-7850K with a GTX 1050 TI. In rainbow six siege (pc game) when I turn the graphical settings to hiqh quality, it runs better than if the graphics were on low quality. My theory is that when using low graphics, the game automatically uses my APU's integrated graphics (which are pretty bad) to reduce power. However, I want to use my discrete graphics card at all times. Any ideas?
Have you tried looking up how to disable the GPU on-chip on your A10? If I am correct, the APU's graphics wont even be used at all if there is not a connection from the motherboard's display port (Which is used by APU) to the monitor, right?
