Question Went to clean PC after cleaning would not boot and red dram_led memok light is on. Need suggestions
Jan 22, 2020
My hardware is
Mobo: z170-e
Ram: ddr 4 corsair Vengeance 8gb have 4
I went to do a clean on my PC as per normal, after compleating my clean, i went to boot up my PC and my Dram light came on my Mobo and my fans run at full power. What i then tried is checking to see if all my cables were attached figuring i unattached some in the process, did not come across any out of place anywhere. After that i proceded to try the mem reset on my mobo, no avail. Then i have tried to put 1 stick of ram in each slot and boot it indivually. still no change. I can not get into my bios either no matter the configuration. Looking for some suggestions as to what i should do next.
