0 024861 Feb 16, 2018 15 0 10 Oct 3, 2018 #1 I am building a pc for my family in Poland and wanted to know if there is an adapter I could buy so that the pc could get power.
Solution L L little_me Oct 3, 2018 If PSU accepts both 120V and 230V input (most do, just do a check) then you could just get normal Euro-plug power cord like this: https://www.amazon.com/Schuko-euro-Power-Cord-H05VV-F/dp/B01INRNA6W alternately, if you want to use US plug, you'd need travel adapter but... for permanent use, they are a hassle
L little_me Splendid May 9, 2015 1,675 37 21,740 Oct 3, 2018 Solution #2 If PSU accepts both 120V and 230V input (most do, just do a check) then you could just get normal Euro-plug power cord like this: https://www.amazon.com/Schuko-euro-Power-Cord-H05VV-F/dp/B01INRNA6W alternately, if you want to use US plug, you'd need travel adapter but... for permanent use, they are a hassle Upvote 1 Downvote Solution
0 024861 Feb 16, 2018 15 0 10 Oct 3, 2018 #3 Would it work with this PSU: https://www.amazon.com/gp/product/B01LYRXRDI/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 Upvote 0 Downvote
0 024861 Feb 16, 2018 15 0 10 Oct 3, 2018 #4 If not would this one work? https://www.amazon.com/SF-Cable-European-Power-IEC320/dp/B006VZI686 Upvote 0 Downvote
L little_me Splendid May 9, 2015 1,675 37 21,740 Oct 3, 2018 #5 both your power cable and PSU should work fine.. Upvote 0 Downvote
