Hello, I am upgrading from a 290 to a fury X, but alas, I pulled the trigger and bought the card on Newegg while completely forgetting about the connectivity issue.
My current set up consists of 3 1080p displays, 2 of which are using DVI and one is using HDMI, and 1 1440p display, which is using display port. All of the monitors run at 60 herz. I noticed that the Fury X just has 3 DP and 1 HDMI, this means I need to get adapters for 2 of my monitors using DVI. The question is, do I need to be careful selecting the adapters? For example do I need active adapters or passive ones will work? I am thinking of getting 2 cheap dvi to DP male to male passive ones, will that be OK?
I need eyefinity to run properly.
Thank you for the help in advance!
