What am I running? (I'm an idiot)
FUNCTOR
95
I've got Windows 98. How do you tell if it is Win 98 SE or regular Win98? This version seems pretty buggy whatever it is. If I have the regular, should I upgrade to the SE? Thanks
All things must surely have to end...
Functor
Right-click on My Computer, go to Properties. If I remember correctly.
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
It says Microsoft Windows 98.
4.10.1998
Does the SE version actually say it's the SE version there? Should I get the SE version?
Functor
try this... go to contropanel> add/remove program> click on windows setup> communication> if there is an option for internet connection sharing, then you've got yourself an SE
If you can't beat 'em kill 'em
athlon "SLOTA" thunderbird 700@1050mhz
I agree with Bubba; I think you have the "original" Windows 98.
Rob
Go to Start click on settings then Control Panel from your Start button. Then go down the list to System. on the General Tab I see.
Microsoft Window 98
Second Edition
4.10.2222.A
If you see that you have the SE version if not it will show you what you have.
You are not a IDIOT. you are just not informed.
