What are some cooling solutions for a FX8350
g335
1,108
Hello
What cooling solution is best for overclocking a FX8350?
Will a air cooler work? Or do I have to go for a liquid cooler?
What is your budget?
A $65 air cooler from noctua or Phanteks will do the job in a reasonably well ventilated case.
What case do you have?
What graphics card will you be using?
Also, overclocking a high wattage chip like the FX-8350 may require more than a basic motherboard.
What is your motherboard?
g335
1,108
I have about 100-150 dollars to spend.
Case is the Enermax iVektor
graphic card for now is the GTX660, will get a better one later.
Motherboard is the Asus M5A99FX Pro R2.0
