What are the best silent fans
gonemad61
268
Hi, as the title says I'm looking for the best silent fans I have a corsair air 540 case and was going to get three 120mm fans for the front and one 140mm fan for the back I was looking at be quiet fans but is there any better.
I personally like my Corsair SP120 Quiet Edition PWM fans. They provide great static pressure and acoustic performance and will not break the bank like many Noctua fans. A fans level of noise can also depend on how many RPMs you have it set to run. If you connect them to a fan controller or if you have PWM fans connected to a PWM header on the motherboard, you can turn down the RPMs to what you are comfortable with and reduce noise even further.
