What are y'all's biggest problem with gaming mice?
Aug 29, 2024
16
I have been wanting to start a manufacturing business, and being a gamer myself, I wanted to base it around that. What are your biggest problems that I could fix in my new mouse and/or possibly some new features like, say a joystick built in.
Unreliable buttons that fail. Some mice have buttons for higher life, but often still fail to use that on the middle click.
I also want both a "sniper" button and the left/right paddle on the mouse wheel (such as dodge left/right). Of the mice I consider (which excludes 100% of wireless mice), it seems to be a problem to find both a sniper button and the left/right paddle. A lot of mice have the left/right paddle hard wired to some function, and even if the rest of the mouse is programmable, they fail to allow that left/right paddle to be reprogrammed. I don't know why the manufacturers often make a programmable mouse, but won't allow that particular button to be programmed.
I'm probably just complaining a lot, but remember that I start by eliminating all mice which don't have high lifetime buttons. In many cases that eliminates entire brands. I really must have that sniper button as well. Nothing remains with the left/right paddle that can be used for random things and which is not hard wired to scrolling up/down. Constantly failing mice are why I start with and refuse to part with high life buttons.
Where would this 'Sniper' button sit
My biggest complaint is size.
Very hard to find a large enough mouse that is comfortable in my x-large hands.
The old Logitech mouseman was about the right size but has not been made for years.
And larger thumb buttons.
I mean I'm 5'9" 150lbs but have very large hands. Size 14 wedding ring.
For a right-handed mouse the "sniper" button is on the left thumb area of the side. If you are gripping the mouse with the right hand, and roll your thumb slightly forward, there would be a button which makes it possible to change the mouse sensitivity (momentarily) simply by shifting your grip forward. It is called a sniper button because it is great for fine movement when zoomed in with optics. You can then essentially play "run and gun" normally, and if desired, use the mouse with much finer movements (it changes the dot per inch sensitivity of the mouse to something smaller) if you are trying to be more precise.
An example of a sniper button is the Razer Basilisk v3. Some images here:
Razer Basilisk at images.google.com
Note on some of the images the left side where your thumb would be. One of the buttons is fairly large, and if you were to roll your thumb forward, then that button would be pressed (not the buttons "above" the thumb, but instead closer to the USB cable). That button is programmable and can be set to different resolutions; presumably you'd set the mouse up normally, and then adjust the thumb to momentarily reduce mouse sensitivity. I use that button a lot in most games.
What that particular mouse lacks is the ability to use the mouse wheel with a "left" or "right" motion. With that the Razer Basilisk would be just about perfect since then one could "lean left or right", or "dodge left or right". I only see this on Logitech, but Logitech is the absolutely worst company in the business when it comes to buttons failing. You can find a Logitech mouse with great setup which includes both a sniper button and left/right dodge/lean, but it is almost guaranteed to fail soon if you use it a lot (the workaround is to not use the Logitech mouse so the buttons don't wear out prematurely).
I also forgot to mention that if your mouse's performance and latency matters, then don't use a wireless mouse. Always stick to a wired mouse if that matters.
Totally agree there. As someone who has large-ish hands, it's hard to find mice that fit my size. I've tried every major manufacturer too - Logitech, Corsair, Razer, and so on. The closest that fits perfectly is my MX Master 3. My Corsair M75 also fits too.
size is a big issue with many mice in general.
where many always seem to be looking to make them as compact as possible, there aren't a whole lot that focus on fitting larger hands. of course they've always been available, but the majority out there are too small.
the Logitech G600 works good, but should be ~1" longer for my palm to rest more comfortably while still offering good fingertip movement control.
the couple i've seen with extendable brackets to allow custom length is a very good idea.
scroll wheel left/right tilt.
should be a standard feature these days, but is not.
weight is another factor that doesn't seem to be often addressed.
those available with adjustable weights seem to still be a niche market after all these years.
on the fly DPI options is a good feature to have.
when editing photos and other precise movement necessities it is a very important factor to have available.
and thumb buttons is a huge factor for me.
i have the majority of the function keys(Home, End, PgUp, PgDown, Insert, Del), the arrow keys, Backspace & Enter all programmed into my left thumb space which makes everything easier plus adds many mouse functions to every game.
the Logitech G600 has the best layout i've ever used out of probably 20 mice i've tried/reviewed over the years.
a secondary right-click button(ring finger button) has also become a necessity for me after becoming used to having it available.
i keep R-CTRL programmed here and makes many functions much easier.
another option that i would think would just be the default after all this time.
when all of this together turns out to be an ~$100 product it means that the mouse needs to be of exceptional quality with a long warranty or the extra money put in just isn't worth it.
