Just as the title suggests, I am looking for a build to get 144 FPS (pretty much locked/stable) at a high-max settings at 1080p.
I’ve looked around and seen people recommending 2080s and 2080Tis and other 1080/1080Ti cards. I think those might be overkill for my use.
Without overclocking, what is the best possible combination of parts I could use to receive the closest thing to 144FPS at 1080p?
If you need a specific game I am looking to achieve this at, it is the upcoming The Division 2. However, I would also like it to work well in other games.
This is the list of parts I am working with now (keep in mind— prices in CAD; my budget is $2000CAD, give or take): https://ca.pcpartpicker.com/list/TFc6ZR
I am unsure what CPU/GPU will do best.
I was thinking maybe 2070/9700k but even then, it’s still quite pricey and I’m not sure if it’d push what I’m looking for, so I am open to other options.
Below are The Division 2’s official recommendations for 1080/60 (up to 4k/60), with this information, what would push a solid 144?
I’m open to hearing all suggestions related to my build. I am a beginner. Thanks!
Recommended – 1080p | 60 FPS
OS: Windows 7 | 8 | 10
CPU: AMD Ryzen 5 1500X | Intel Core I7-4790
RAM: 8 GB
GPU: AMD RX 480 | Nvidia Geforce GTX 970
VRAM: 4 GB
DIRECT X: DirectX 11 | 12
High – 1440p | 60 FPS
CPU: AMD Ryzen 7 1700 | Intel Core I7-6700K
RAM: 16 GB
GPU: AMD RX Vega 56 | Nvidia Geforce GTX 1070
VRAM: 8 GB
Elite – 4K | 60 FPS
CPU: AMD Ryzen 7 2700X | Intel Core I9-7900X
RAM: 16 GB
GPU: AMD Radeon VII | Nvidia Geforce RTX 2080 TI
VRAM: 11 GB
RAM: 8 GB
VRAM: 4 GB
RAM: 16 GB
VRAM: 8 GB
Elite – 4K | 60 FPS
RAM: 16 GB
VRAM: 11 GB
