what cable should i choose for 144hz
The DP cable would do it. It's listed as "1.1", but a DP cable is a DP cable. What matters is the output of the card (1060 has DP1.4) and the monitor (has to be at least 1.2 for 144Hz0.
The Displayport cable can definitely do it. I'm not sure about the DVI
The DP cable will work fine. I wouldn't get the DVI - D cable, but that's just me. Either will work fine just take your pick.
