G guest555 Reputable Jun 12, 2014 168 0 4,680 Oct 13, 2018 #1 I believe HDMI is good for 1080p but there are better options for higher res and refresh rates. Is the dual link DVI better or displayport?
Solution Glenwing Oct 13, 2018 Dual-Link DVI is good only up to 1080p 144 Hz or 1440p 60 Hz. DisplayPort is normally used for 1440p 144 Hz. HDMI can also be used if the monitor supports HDMI 2.0 (not all 1440p 144 Hz monitors support this).
B bmockeg Dignified May 11, 2018 5,170 358 14,990 Oct 13, 2018 #2 Displayport is preferable Upvote 1 Downvote
k1114 Titan May 2, 2010 14,236 93 75,540 Oct 13, 2018 #3 The monitor will come with a cable (or different cables) that is capable of running it at max res and hz. I don't think I've even seen a modern 1440p/144 monitor that doesn't come with a dp cable. Dvi is being phased out. Upvote 1 Downvote
Glenwing Splendid Aug 8, 2015 3,208 350 25,990 Oct 13, 2018 Solution #4 Dual-Link DVI is good only up to 1080p 144 Hz or 1440p 60 Hz. DisplayPort is normally used for 1440p 144 Hz. HDMI can also be used if the monitor supports HDMI 2.0 (not all 1440p 144 Hz monitors support this). Upvote 0 Downvote Solution
