What cables do i need for this build
Apr 19, 2018
52
i am going to build a new gaming pc. i am going to use a semi modular power supply and i am just wondering what cables i need fo this build.
CPU - intel core i5 8400
Motherboard - Asus Prime Z370-P
RAM - Corsair Vengeance LPX DDR4 2666MHz 16GB CL16 (2x8GB)
GPU - Nvidia Geforce GTX 1070 ti (Founders Edition)
SSD - WD Green PC SSD M.2 SATA III 120GB
HDD - Seagate barracuda 1TB 3,5"
Case - Phanteks Eclipse p400S Glass Silent
CPU Cooler - Cooler Master Hyper 212 Evo
OS - Windows 10 Home 64 bit
the power supply i am going to get i an EVGA BQ 650W Hybrid Modular 80+
You will get all the cables you need with the PSU. You only need 2 SATA Cables and thats it
i mean, what of the cables that i get with the power supply do i need to use for this build
the only other extra cable need may be a eps 12v extension cable if you want the eps cable to go behind the mb tray and out. for those sata cables see how long you need them before you buy. also at your local hardware store or online pick up some black zip tyes to clean up your wires. the two errors people do is have wires over the cpu cooler fan or wires to close to gpu fans. not fun when a fan cuts a wire or fan blades break from wire hit.
