Rig:
Distilled water system. Silver coil in reservoir. Cleaned first with SysClean-HPD mixes using a little CP-701 pump. Pump at bottom of case, 90' compression fitting to GPU full board block, CPU block, snake fittings to create gentle U bend into triple rad outside and on top of case, very restrictive rotary extension into bottom of 100mm XSPC reservoir at top of loop, in-line filter at outlet of res, in-line (not T-piece) temp probe shortly before pump. 1/2" ID tubing throughout with no kinks.
No problems with DDC-T+
but inadequate cooling to overclock. Switched pump to a D5 Vario to get higher flow and that's where the trouble started.
Symptoms:
Filled system one gulp at a time then sealed the res and turned pump on to start bleeding the system. FOAMmmmmm! Stop that!
Let it settle and turn speed to lowest... bleeds fine. Eventually there's little bubbles that don't reach res bottom where it's outlet is.
Turn up speed a little... bubbles start reaching pump.
Turn up speed a lot... foam fills the res. Stop that!
Let it settle and been using it at slowest speed with little bubbles that don't reach the res outlet.
Situation:
It's usable at stock speeds. The GPU runs a little hotter than the CPU which wobbles about 45'C.
Overclocking:
Rig ready its overclocking time. Using ASUS AI Suite with a 5:8 ratio, Q9550 : DDR3 1333 system is stable at 3.5GHz. Runs Office, VLC, interweb... solitaire :S but try to play a game and after a while BSOD. Windows?! What do you mean the CPU isn't working properly, the inline water temp display was at 38'C. GPU display was 48'C, CPU display was 45'C. Speedfan consistently shows that the GPU block sensor tends to be 8'c lower than the chip sensor and agrees with the CPU block sensor. So WTF?
Fired up Speedfan to look at the core temps and started an intel burn test... the CPU temp shot up. Stop that! I saw 94'C before the cores promptly returned to 38'C.
No more OCing until this is resolved 🙁 I feel sure I need higher flow to get the heat away, but need to stop the FOAMmmmmm! Help please.
Symptoms:
Situation:
Overclocking:
