[SOLVED] What case do I need for my build?
Jan 5, 2019
11
Suggestions on a case for my audio workstation.
1. Has to fit the components below
2. Maximum £80
3. Quiet as possible
4. USB 3 on front
PCPartPicker part list: https://uk.pcpartpicker.com/list/HpRq8Y
Price breakdown by merchant: https://uk.pcpartpicker.com/list/HpRq8Y/by_merchant/
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor (£322.50 @ Aria PC)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£23.00 @ PC World Business)
Motherboard: MSI - Z370-A PRO ATX LGA1151 Motherboard (£89.99 @ CCL Computers)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory (£123.59 @ Amazon UK)
Storage: Seagate - Barracuda Compute 500 GB 2.5" Solid State Drive (£69.95 @ Amazon UK)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive (£36.97 @ Aria PC)
Video Card: Asus - GeForce GT 1030 2 GB Phoenix Fan OC Video Card (£81.30 @ PC World Business)
Power Supply: be quiet! - Straight Power 11 450 W 80+ Gold Certified Fully-Modular ATX Power Supply (£78.48 @ Ebuyer)
Wireless Network Adapter: Asus - PCE-N15 PCI-Express x1 802.11b/g/n Wi-Fi Adapter (£12.99 @ Box Limited)
Keyboard: Logitech - MK345 Wireless Standard Keyboard w/Optical Mouse (£32.98 @ PC World Business)
Total: £871.75
Thanks
you need any compact mid tower or bigger. I would suggest a normal mid tower to fit everything. your gpu is very small so it wont really be an issue, all you need to look for is heatsink clearance which for the hyper 212 is 120 x 80 x 159 mm.
here are a couple of cases that will suit your need, but I suggest you go on amazon and just look for cases that look good, while checking for cooler clearance. non of the other components need any weird cases. (honestly neither does the 212, most cases, but not all do have space for it, but just to make sure...
https://www.amazon.com/dp/B06XS364S8/ref=sr_1_10_twi_col_4?s=pc&ie=UTF8&qid=1547024716&sr=1-10&keywords=pc%2Bcase&th=1
great brand, great case, seen it in real life and has actually...
great brand, great case, seen it in real life and has actually built a pc in it once. really nice, but not my type in terms of looks.
https://www.amazon.com/Rosewill-Gaming-Window-Pre-Installed-Computer/dp/B01IT0TDY6/ref=sr_1_1_sspa?s=pc&ie=UTF8&qid=1547024716&sr=1-1-spons&keywords=pc+case&psc=1
have heard of the brand, not a popular one but definitely a mid range on, not expensive or fancy, but it looks okay I guess.
https://www.amazon.com/Computer-digital-control-lighting-CA-H500W-B1/dp/B07C3STSDB/ref=sr_1_3?ie=UTF8&qid=1547024683&sr=8-3&keywords=cases
de cream de la quire (am not French, have no idea what I said or if its right) this is a really REALLY good case. its on the edge of your budget tho (90$ is about 75 pounds or so) my personal pc has an h700i from them, and I loved every second building In it. amazing fans, amazing cable management and solid looks. this is a compact mid tower, will fit your mobo and such. has solid upgradeability and a great rgb eco-system (but thats for bants) it is made of steel and tempered glass only btw.
but you should choose whatever you want.
looks always matter even if its under your desk. but if you really dont care about any of that, and only want airflow, I would suggest getting a case for 40$ or 45$ and slapping on a couple corsair or noctua fans. or getting the corsair one I recommended earlier.
I can suggest a couple of cheap cases and fan addons if needed
