Question What case fans do I get?
LuKaWin10
Notable
May 6, 2024
502
89
970
Hello, what Case fans do I get for my PC. Specs I think you want to know:
Motherboard: P35-DS3 rev 2.1 (2 SYS_FAN and 1 PWR_FAN which I can use as SYS_FAN)
Case: DELUX Mid-Tower ATX "BMW" style case, color: black. It has 3 mounting things for 80mm fans and 1 120mm fan. Pretty much I can have 3 fans max or I get a splitter
RAM: Soon will be 8 GB G.SKILL 800 MHz
GPU: ASUS GT 730 2 GB GDDR5 Kepler
CPU: Q9550 OC to 3.4 GHz
If you need more info just ask, I want some great fans that work well for airflow and more. I want great temperatures!
Is this the case you're working with? If yes or no, please host images of the fan mounting positions in your case and pass on the link to said images since we don't allow hosting of images on our forums.
Okay, I will send the imgur link later when I come back home. Now I gotta finish up some work. But then I will show every mounting position for the case.
And this case, this is pretty much it, except that it is fully black, and on the panel that is moved from the picture that shows the components and everything that one has 1 mounting part for an 80mm fan too. So 4 in total for the case.
Later I will provide images of the mounting areas!
