What case should i get? H440, R5, be quiet 800, or phanteks enthoo pro?
ChipsAhoyMcCoy
23
Im looking for a new case that is silent and sexy for under 150. H440, R5, be quiet 800, or phanteks enthoo pro? I also want good airflow.
Hard to choose. I've been looking at several of those, the r4/5, enthoo pro and the be quiet 800. I might have gone for the 800 but no side window (finally have a decent looking build so wouldn't mind a windowed case this time around). I like the options and how well thought out the enthoo pro is, especially since it comes with a psu cover standard (with the windowed version) rather than making it a separate purchase and the fact the case pretty much comes completely apart (if you ever needed full access for deep cleaning, painting etc.) rather than riveted. Tough to choose at that point really. Personally I've pretty much settled on the enthoo pro for the reasons listed above and I like that the usb ports are front mounted rather than...
EP
4
It's really up 2 your priority.
Best looking: H440
Quiet: BQ base case 800
Overall above average: R4/R5
Best airflow cooling: phanteks enthoo pro
My personal favor is phanteks enthoo pro. It's a bit larger, but you can't find a better airflow/cable management/dust filter everywhere case for $99.
Mine use 1x 200mm, 3x 140mm and 5x 120mm Cougar fans + Dark Rock 3 cooler, but it's still Ok quiet when full loaded. Of course, it can be much louder if you use cheap fans.
If you don't like bigger size case, h440/R4/R5 are the best picks.
I choose a bit bigger case just because I don't move my case much and it's spacious for airflow and future upgrade. H440/R4/R5 will lose many expansion bays/ airflow space if I go sli with 2 larger GPU or build custom water cooling in the future.
Hard to choose. I've been looking at several of those, the r4/5, enthoo pro and the be quiet 800. I might have gone for the 800 but no side window (finally have a decent looking build so wouldn't mind a windowed case this time around). I like the options and how well thought out the enthoo pro is, especially since it comes with a psu cover standard (with the windowed version) rather than making it a separate purchase and the fact the case pretty much comes completely apart (if you ever needed full access for deep cleaning, painting etc.) rather than riveted. Tough to choose at that point really. Personally I've pretty much settled on the enthoo pro for the reasons listed above and I like that the usb ports are front mounted rather than top mounted. Dust is inevitable and I'd rather not have it settling into my usb ports. Before considering that and taking a long hard look my previous consideration was the r4 blackout.
Can't really say it's the best case for everyone especially since looks play an important role and everyone's taste is different - but given the $100 price, don't see anything beating the enthoo at that level. I like all those cases, even the 800 - just wish it wasn't lacking a window. A lot of people don't like windows, but I like the clean lines and look of the enthoo and r series from define. They pulled off having a 'minimalist' window without looking like a carnival show. Not every windowed case has to be fitted with 10+ enermax tb vegas quads trying to give someone an epileptic seizure lol.
