Hi,
I was wondering if anyone might know if something other than the network card in a laptop could affect the internet download speed? I am having an odd issue that i have never seen before with a new laptop i just got. When i use various internet speed test online from the laptop i am getting about 25% of the connection speed i have contracted for with my ISP.
It is only happening on this one Acer Aspire 3 laptop. I have 3 other desktop machines and 8 laptops at home and 3 different wifi routers. No combination of those machines and the 3 routers produce slow results like this. they all test out fairly close to my max ISP speed when i use the online internet speed tests.
I have tried testing the speed of the internet connection while connected to my router by a wifi (5g) 433Mbps link speed connection, and a hardwired cat6 ethernet connection with a 1Gb link speed. same results. 2 laptops side by side, accesing my network the same way (tried 5g wifi on both and ethernet on both) over the same router ...on the new acer aspire
3 i get about a 50Mbps download rate (acording to Ookla Speedtest & other online internet speed tests) and with my dell inspiron (and pretty much all other computer in my home) , i get around a 198Mbps download rate over a 200Mbps ISP connection from comcast.
I thought the new Acer Aspire 3 might have a crappy wifi card in it (but that wouldn't explain the slow speed over ethernet) so i plugged in a usb 5G wifi card and tried it with that. similar results.
The Acer ASpire 3 has the AMD a9-9425 cpu and has 6GB memory, running windows 10 home. and has the realtec rtl8168/8111 PCI-E gigabit enternet nic and an Atheros/Qualcomm QCA9377 80211.ac Wifi network adapter.
My isp is comcast and i have 200+Mbps contracted speed with them for my internet.
Is there some component on the laptop that could be causing the slow download rate, other than the network cards? The cpu doesn't seem to be slow or under powered in any way.
