[SOLVED] What components should i upgrade and to what
Math844vrte
32
What components should i upgrade and to what ps cpu and gpu budget only around 400-500$
Motherboard: asus b150m pro gaming
Cpu: i5 6500
Cpu cooler: arctic freezer 11
Ram: 2x4gb 2133mhz hyper x
Hdd/ssd 750gb hdd dont know name
Psu: corsair 450watt
Gpu: gtx 1060 3gt-oc
Case: aerocool si-5101 advance
To do any real change to your CPU you need a full upgrade. The best CPU you can do is an i7-7700 and that runs $300 by itself. To upgrade everything within a $500 budget isn't possible. However, we can get your a better GPU and PSU.
PCPartPicker Part List
Video Card: EVGA GeForce RTX 2060 6 GB KO GAMING Video Card ($313.98 @ Newegg)
Power Supply: Fractal Design Ion+ 560 W 80+ Platinum Certified Fully Modular ATX Power Supply ($101.99 @ Newegg)
Total: $415.97
Generated by PCPartPicker 2020-07-23 14:55 EDT-0400
The 660W version of this PSU runs only $20 extra, but at 560W it is plenty for a 2060 & i5-6400.
Total: $415.97
Total: $415.97
The price i max will give for gpu and cpu is both max 400-500$ the whole pc is max 1600$
here's what i would do.
I would do the same thing the guy above would,but i would also upgrade ram to 16gb.Make sure to get the same kit as you already have.Also it says that the best cpu for this mobo is 7700k which can be overclocked on your board (https://www.asus.com/rs/Motherboards/B150M-PRO-GAMING/HelpDesk_CPU/ ).
So here are the upgrades i would do:
-Get a 2060
-Get a new psu
-Get more ram
Later on you can save up money for that 7700k which you will overclock to get the best performance out of that i7.
-Get a 2060
-Get a new psu
-Get more ram
K series CPUs cannot be overclocked on non Z series motherboards.
