[SOLVED] What connectors do i need for a Radeon R9 280
D
OKAY. That's a pretty OLD gen video card, and it does NOT require any external power connectors as well. Since it takes power from the motherboard's PCI-E slot itself.
So you current PSU migth have worked for this GPU, but if you want to use the R9 280, then get a compatible PSU.
You need PCI-E cables. What's the make and model of your PSU ?
That's fine. But what's the exact MODEL number of brand/make of this PSU ? Does it come with PCI-E cables ?
It's all in the details. There are several hundred (if not thousands of) 500 watt power supplies. We need the exact model number. However, if you state it only has the one PCI-E power connector (6-pin), then it's not enough to handle your new graphics card.
-Wolf sends
That looks like some budget low-end PSU model. It also lacks PCI-E connectors, as evident from the SCAN UK website, if I'm not mistaken.
Connectors
  • 1 x 4-pin ATX 12V
  • 1 x 4-pin FDD Power
  • 2 x 4-pin Molex
  • 3 x SATA
• 20+4 Pin Main Connectors 1
• 4-Pin 12V Connectors 1
• SATA Connectors 3
• 4-Pin Molex Connectors 2
• Floppy Drive Connectors 1
Using MOLEX adapters isn't recommended. If any PSU model lacks sufficient PCI-E cables, then it was not meant to be used for and to power any GPU. You need to buy a compatible high-quality PSU.
