What connectors goes into a hard drive and dvd drive from the PSU?
porke
18
Hi, I was wondering what connector goes into the hard drive and what connector goes into the dvd drive
Also, are LED sticks connected to the power supply or the motherboard?
Thanks
Depends, internal HDD's and DVD drives will either use IDE or SATA when it comes to data transfering and when it comes to power they can either use a SATA power or a Molex connector.
And by LED sticks i assume you mean cold cathodes, which do connect to the PSU, but they require a converter inside your system(because they need AC power) which comes with the cathodes themselves.
