What Cooler Will Fit In The S340 Elite
Lewis_40
19
Can anybody out there let me know what AIR coolers can fit into my case the S340 Elite, besides the hyper 212 evo that is already in my system. Also will there be an issue with the ram clearance. Any help needed, thanks.
MSI z270 Sli Plus
Corsair Veng Ram 4x 8gb
These are a few options that will fit.Id recommend going with Cooler Master as I've had good experiences with them before. You will need to check processor compatability but these fit most of today's sockets. :)
https://pcpartpicker.com/product/KzfmP6/cooler-master-cpu-cooler-rr212x20pma1
https://pcpartpicker.com/product/fFWrxr/cooler-master-masterair-ma610p-534-cfm-cpu-cooler-map-t6pn-218pc-r1
https://pcpartpicker.com/product/bHcMnQ/cryorig-h7-quad-lumi-490-cfm-cpu-cooler-h7-quad-lumi
Cheers and good luck,
lmnvum
I would honestly recommend sticking with the 212 Evo because they run great, any cooler with the height of 161mm or under will fit just fine.
I will pop a link to a few in a minute. :)
Cheers,
lmnvum
lmnvum
