I'm having some cooling issues with my CPU.
When I stress test my PC the CPU temperature reaches 95 degrees celcius after just a minute or so.
The CPU is an Intel Core i7-4790K and it is not overlocked. It has the Noctua NH-U9S cooler installed, which as far as I know should easily be able to cool the CPU.
Might be worth noting that the CPU originally had a stock cooler on it, but due to the CPU overheating in the summer and shutting down I replaced it with the current Noctua one, but as you can see I'm still getting high temperatures.
Not sure what I should do to fix the high temps.
These are my PC components:
Motherboard: ASUS Z97-A ATX
CPU: Intel Core i7 4790K 4GHz, 8MB
SSD: Samsung SSD EVO 850-Series 250GB
HDD: 2TB Toshiba 7200rpm 64MB
PSU: EVGA Supernova G2 750W, 80+ Gold, Modular
GPU: MSI GeForce GTX 970 Gaming 4GB
RAM: Crucial 16GB (2x8GB) CL9 1600Mhz Ballistix Sport
CASE: Cooler Master HAF 912 Plus Black
CPU COOLER: Noctua NH-U9S
