Question what could go wrong if I lower GPU power limit and temp limit ? ty
Nov 28, 2019
19
Hello ,
I just built a new pc 1 month ago , I have Geforce 2060 RTX super , had some heat problems with some games , they crash when it hit 65temp , when I use Msi afterburner and lower temp and power limit and increase fan manually to 70 , it doesn't go above 63 and the game ( Monster hunter world ) don't crash anymore , I cnat' figure out the problem I'm totally new in this
List your full PC specs.
65c is fine for a GPU, so it's possibly something else causing the crashing. When you say games crash, what happens? Do they crash to your desktop or does the PC restart by itself, or is there a BSOD?
Nov 28, 2019
19
hello , thank you for replying
pc spec are :
Win 10 pro 64
16G Ram
AMD Ryzen 5 3600
Nvidia Geforce RTX 2060 Super
Asus prime B450M-K
HDD 1TB
SSD 240
PSU Corsair VS 550 Watt
the game crash to desktop sometime it messes with graphic driver it says graphic device crashed
GizmoMKD
236
32
Hello ,
to me, sounds like GPU problem... 65C is very normal under load for GPU.
Nov 28, 2019
19
@GizmoMKD yes , only MHW or destiny 2 that crash with that temperature , other games like plagues tale , assassin's creed odyssey , played them on high settings nothing happens , I used superposition with 1080 high GPU and results are ;
I used Superposition benchmark 1080high for results I got :
FPS min 71.28 average 87.06 max 110.23
GPU tem : min 30 .0 max 74.0
GPu utilization 98%
with no problem of course
Sep 16, 2019
6
Hello ,
It is nothing but a GPU problem
