Phazoner :
Please, stop talking about things you just don't know.
GTX 1060 = RX 480/580 = Xbox One X.
There isn't a current AMD GPU which matches PS4 Pro power as it is 4.2 TFLOPs and the 570 is over 5 TFLOPs and the 560 is 2.6 TFLOPs. Neither are current Nvidia GPUs. I think the closest is the 2015 AMD 380X which at stock speeds is 4 TFLOPs.
The PS4 and Xbox One double Jaguar CPU is tremendously weak and is solved in the consoles with very low CPU calculated physics, shadows, animations, etc, under the lowest settings available in some top graphics games in PC, just like the latest multiplatform games that PS3 and Xbox 360 got. Even the Intel i3-2100 from 2011 has more raw power than PS4's CPU, as Jaguar was conceived as a low powered CPU for tablets.
If you want to know which PC CPU matches its power that's pretty much the answer, but as I said that CPU survives with very low and specific settings, and with most of the games capped at 30FPS or dancing between 30FPS and 60FPS like latest Battlefields. If you want to know which CPU do you need to build a PC which can run at least like the PS4, you can go for very low budget processors like the AMD FX which you can find used at ridiculous prices, but usually you will want to play in better conditions, specially if you are going to play first person shooters (playing FPSs at 30FPS with a mouse is a pain), so if you want a cheap but fairly good CPU just go with a cheap quad-core Intel Core or Ryzen.
I feel like you don't know how to research information very well
Also TFLOPS isn't everything and if you actaully look up the Jaugaur APU you will find it to be a RX 480 squished with no direct compassion for the CPU besides maybe a Opteron X115 in Chiplets.
The PS4 Pro Graphics
Pixel: 58.3 GP/s
Texure 131.2 GT/s
Bandwidth 217.6 GB/s
Techinally a Ryzen 5 2400GE is only 4 Cores (8 Threads) but it is newer, double the clock speed and the VEGA chip is also half. But once again newer (by 2 generations) and higher clock speeds. It ends up outperforming the PS4.
Once again there is no easy way to do a direct comparison to custom hardware. Even if you happen to have the exact hardware, you will find unless the game is optimized for the console / data paths, it will not preform the same. This is why a VEGA can't handle 4K gaming very well, yet a 5 year old video card can do 4K30 (with some upscalling and super sampling). All consoles are identical so making games is way easier and can be optimized.
