what cpu temperature should i check when overclocking a cpu is it SYSTIN/CPUTIN/AUXTIN/TMPIN3?
BadassLayzee
18
On CPUID HWMonitor the temperatures from motherboard are:
SYSTIN 30c.
CPUTIN 33c.
AUXTIN 63c.
TMPIN3 60c.
The CPU Package temperature show 51c.
What temp is the most important to watch.
Whit prime95 it reaches a package temparature of 100c, is it still good ?
specs:
PSU SilentStorm CM 460
CPU AMD A8-5600K APU with Radeon(tm) HD Graphics ( overclocked with x-boost asrock)
CPU Cooler Scythe Lori (SCIOR-1000)
gpu AMD Radeon R7 265
Core 925MHz(950MHz) Memory 1400MHz(1500MHz)
MB ASRock FM2A88M Extreme4+ Socket FM2+
SPD(RAM) Crucial Technology Ballistix DDR3 8GB 1600 MHz
Hi Someone Somewhere,
Its strange, On AMD Overdrive the Thermal Margin is arround 60degrees.
and it drops under load to 25degrees, as seen from my knowledge its completley normal.
On A-Tuning the CPU temperature is idle at 36 degrees,
what i do with that package temperature in CPUID HWMonitor that is reaching 100c?
everything else looks normal.
thnx for that fast rply,
