What does 'IF' stand for on Nikon lenses?
Archived from groups: rec.photo.digital.slr-systems (More info?)
"paul" <paul@not.net> wrote in message
news:eOCdnUeausNu9kXcRVn-2g@speakeasy.net...
> Mine just says ED but I don't see that described elsewhere.
IF=Internal Focus, not all lenses are IF. IF lenses barrells don't rotate
nor do the lenses get longer as you focus closer.
Internal Focus. With IF lenses, the front element does not change
position while focusing. (The focal length does change, but that's
another story).
Michael Benveniste -- mhb-offer@clearether.com
Spam and UCE professionally evaluated for $419. Use this email
address only to submit mail for evaluation.
> another story).
Hmm so what difference does this make in the real world?
I got a Nikon AF 28-200mm f/3.5-5.6G ED but when I google that all I see
is the same thing with IF added. I didn't get a lense hood is the only
difference I noticed. The lense does not rotate when I focus, did they
just forget to print IF on it?
Non-rotating front elements make it much easier to use such filters as
polarizers and rectangular split NDs.
"Internal focus for fast AF operation" (first google hit, then clicked
on an IF lense
http://www.nikonusa.com/template.php?cat=1&grp=5&productNr=1940).
/Allan
paul <paul@not.net> writes:
> > another story).
> see is the same thing with IF added. I didn't get a lense hood is the
> only difference I noticed. The lense does not rotate when I focus, did
> they just forget to print IF on it?
The non rotating while focussing is a complete red herring. It is
solely about whether the lens assembly changes length.
B>
It does not change length when focusing, only when zooming.
If you use pol-filters or 'Cokin' filter holders, a non rotating front element
is a blessing, neigh, a neccesity.
-- r.p.e.35mm user resource: http://www.aliasimages.com/rpe35mmur.htm
-- r.p.d.slr-systems: http://www.aliasimages.com/rpdslrsysur.htm
-- [SI] gallery & rulz: http://www.pbase.com/shootin
-- e-meil: there's no such thing as a FreeLunch.
> another story).
does that mean that the lens does not have to pump air in and out
as it is zoomed and focused?
Alan Browne <alan.browne@freelunchVideotron.ca> writes:
> element is a blessing, neigh, a neccesity.
While this is true, really doesn't have much to do with the IF being
discussed.
B>
It means IF you're lucky you might get a worthwhile picture.
"Crownfield" <Crownfield@cox.net> wrote in message
news:41DA0CD0.71D9@cox.net...
The lens still has to move air around as it repositions element
groups. I would guess that IF lenses pump _less_ air in and out,
but I doubt that they are truly isolated from outside air.
Latest posts
