R RKN98 Commendable Oct 30, 2016 9 0 1,510 Dec 23, 2016 #1 As title says. I can't get to insert completely in the motherboard and i wanna make sure if it's useful anyway
Solution ThatVietGuy Dec 23, 2016 Does your case have a headphone jack on the front somewhere? The HD Audio cable is for that.
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Dec 23, 2016 Solution #2 Does your case have a headphone jack on the front somewhere? The HD Audio cable is for that. Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Dec 23, 2016 #3 One of the ports is filled in on the HD Audio plug , so make sure you are inserting it properly into the board. Upvote 0 Downvote
A Armond_Lending Commendable Dec 23, 2016 2 0 1,510 Dec 23, 2016 #4 Might be for the SPDIF Upvote 0 Downvote
R RKN98 Commendable Oct 30, 2016 9 0 1,510 Dec 24, 2016 #5 One of the ports is filled in on the HD Audio plug , so make sure you are inserting it properly into the board. I'm inserting it correctly. Still not going through all the way. I'll try using my earphones after i flash the OS Thank you for your fast replies! Upvote 0 Downvote
