[SOLVED] What fans are compatible with my motherboard? (asrock ab350m pro 4)
xristosv55
6
Hello. I hope this is the right place to ask .
One of my fans died and I was thinking of replacing all of them with rgb ones. However I can't understand all this argb,rgb, 3 pins, 4 pins stuff and I would like some help before I get something that wont work with my system.
Ideally i'd like fans that can change colors by using an app but remote controlled ones are fine too.
Here are some pics from my motherboard's manual to save your time, I can't figure them out 🙁
View: https://imgur.com/a/8J90MEL
Which connectors exactly you do not understand?
#2 - is 4pin fan connector for cpu fan ( drives spinning part),
#6 - is RGB connector for AMD boxed CPU cooler with RGB,
#9 - is USB connection for AMD boxed CPU cooler with RGB,
(illustration in manual page 23)
#16 - is 3pin system fan header (drives spinning part),
#23 - is 4pin system fan header (drives spinning part),
#5 - is 12V RGB connector for remaining RGB devices.
#6 - is RGB connector for AMD boxed cooler with RGB,
#9 - is USB connection for AMD boxed cooler with RGB,
So #2,6,9 are all for the cpu cooler?
Do rgb fans come with 2 connectors, one for the actual fan and one for the led? and the number 5 is the led one?
So if i understand correctly my mobo isnt compatible with argb fans, right?
Sorry if i seem stupid with all those questions but i genuinely do not understand. I wonder how i managed to build my pc
