What is 'CPU min fan speed' setting in BIOS?
bizowner1
44
In the BIOS settings for my MSI G41M P33 mb, I see 'CPU Min. Fan Speed (%)'.
What exactly does that mean? Is that a percentage of its maximum speed capacity?
I also see 'Target' [something, cant recall exact words]. Is the the target temperature after which the fans should speed up to bring temp down to the 'target'?
This is the first time I've explored these settings and I'm trying to learn, if anyone can help me understand, I'm very appreciative. Thanks!
You're basically right on both counts, though the maths it does is a little bit more tricky.
Min fan speed is the minimum percentage of 12V that the fan needs to start spinning - if you set it too low, your fan won't start, and your motherboard will likely refuse to boot because it can't detect a fan.
Ok. Thanks for the explanations. Why would my cpu fan be running at or above 1580 (rpm) at all times ? Is that some sort of min. rpm for the fan? It is a very noisy fan (new) & I'm trying to figure out how to reduce the rpm when the cpu is cool. Thanks.
I have the option in the AMI bios to 'set 'CPU Min. Fan Speed (%)' - but it appears to do absolutely nothing to fan speed (at least I am unable to slow it down below 1500). Any ideas as to what else I can do? It is an MSI G41M P33 motherboard with AMI bios just purchased to replace a failed mb
Yep, it's a four pin connector.
The only thing I can think of is that there is a *little* bit of dust down in the cpu fan when i look inside the pc case. Could that be enough to cause it to get 'hot'? The cpu runs at about 29 to 34 C temps but the fan is always on 1500+ rpm. BTW, is that rpm simply a normal minimum RPM for cpu fans?
Can I just hold my standard home vacuum 'crevice' attachment up to the cpu fan to vac it out? Or is that too risky for static??
