What is difference between dual and quad channel ram?
yogesh_gamer
97
I was looking for corsair 8gb ram. And found that there are channels (dual and quad). What is d difference? And which one is faster?
And also what is d difference between various categories like vengeance and platinum etc. Any comparison table ?
Update: It may be dumb ques. Suppose, i order for 8 gb ram (2x4gb) dual channel. Will i get two stick of 4 gb or 1 stick?
I am confuse. I was watching unboxing of ram on youtube and that made me to ask this dumb* ques.
Update 2: I got it. dual channel means 2 stick of 4 gb ram. So how much dual channel is faster than single module. And also i was looking for a 8 gb ram (1x8gb) and its configuration is quad core. what does it mean?
Quad channel RAM kits offer wider bandwidth on motherboards that support it, which results in faster transferring speed. If you motherboard only support dual-channel RAM, then getting quad-channel kit won't get you any increase in bandwidth over dual-channel.
The Platinum RAM series from Corsair offer better heat-spreader and OC ability over normal series like Vengeance.
How much there are difference ? I want to do gaming and general work on my PC.
Single Module vs Dual Module vs Quad Module ?
Corsair Vengeance RAMs has decent performance, not really good for OC-ing, big heat-spreader. Will not fit some big full-tower CPU cooler, thou.
