Question What is happening with my monitor ?
Metatrix
15
I have a monitor that started flickering bands of faulty pixels. There is also a ticking noise accompanying the flickering.
Everything was fine, now it is constant.
Other monitors are fine.
I tried other monitors plugged in the same port on the GPU, and they are working fine.
It is not the cable either.
What can that be?
Here is a short video of what it looks like.
View: https://www.youtube.com/watch?v=QeBvmd0F2NU
If other panels are not exhibiting the same issue while on the assumed faulty monitor's display output port, then the issue can be compounded to the monitor being the fault. I'm assuming you swapped cables to rule out a faulty/failing cable?
You should pass on the specs to your build, like so;
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Reactions: Metatrix
Your assumption is correct.
CPU: i5-14600KF
CPU cooler: DeepCool LS720 SE
Motherboard: MSI MAG B760 TOMAHAWK
BIOS Version/Date: American Megatrends International, LLC. A.70, 1/11/2024
Ram: G.SKILL Trident Z5 RGB 32GB
GPU: GIGABYTE AORUS GeForce RTX 4070 SUPER MASTER
PSU: FSP Hydro G Pro 850W (Brand New)
OS: Windows 11 Pro
MONITOR: ASUS Tuf Gaming VG32VQ1B
