What is my next step in System Assembly?
davidnavratil
33
Absolute Newbie Dave here - I've got all my parts in for my 1st system build which consists of!
MB - ASRock FM2A88m Extreme 4+
CPU - AMD A8-6500
Case - ThermalTake Core V41
Ram - 2 X 8gb Kingston 1866
PS - EVGA Super Nova NEX 860W
Storage - 120 GB Crucial SSD
No Video Card, Hard Drive or Opitical Drive
I have installed the 2 pcs of Ram and I also have installed the CPU and Fan onto the MB.
My questions is should i install the power supply 1st into the case or should I install the Motherboard 1st? The Case is very large and roomy, I've removed the HD cages since I will put the SSD on the backside of the MB plate out of sight!! Any Help is really appreaciated!! Tks DN
I have done exactly that, I removed all the extra standoffs and all holes line up perfectly with MB! I did have trouble connecting the CPU fan to the motherboard earlier. I had problems with the clips attaching right. It hard to work with when you have thermal paste on the heat sink!! Hope I have it secured right!! - Tks, DN
