What is my problem?
Tyreese Sweeney
14
Well, recently I purchased components to make my own computer (thank you Black Friday!)
I had purchased...
A Gigabyte GA-990FX revision 4.0
An AMD 8350 Processor
A Sapphire Raedon 290 Tri-xx
A Rosewill Hive 750watt power supply
A Hyper 212 Evo Aftermarket CPU Cooler, and case fans and a case itself.
So, after hooking all of this up and putting my graphics card in, my computer itself beeps up. I know that the graphics card works, and I know the motherboard works. The graphics cards three fans can be seen spinning, and the Hyper 212 Evo plugged into my 990FX itself is blowing air.
However, whenever I plug a DVI cable in the graphics card to get an image onto my monitor, I get a NO SIGNAL.
To confirm that this wasn't the graphics card, I had taken out my 545 GT from the Alienware x51 I had bought three-four years ago and swapped it inside, it had its fans spinning and was not working either.
I swapped PCI Express slots, but soon discovered no matter what my monitor had a NO SIGNAL error. The internal speaker that came with my motherboard has not said a single thing (though, to be fair I messed up it's pins and went back in to fix them.) Even after several reboots, there is no short beep there is nothing.
I think the NO SIGNAL could be caused by my monitor having to readjust sizes because my new components don't have any drivers installed on them?
Also, I had an old hard-drive that I had forgotten to wipe and i intended on wiping with my new Windows 7 disc. Could that be a problem? Would I have to wipe that before putting it in?
This is my first computer build, and I'm a fifteen year old so I'd appreciate any help / scholarly advice you can give me.
If this is the wrong board for this, I apologize.
I have gone through this checklist, I've read the forums rules and have heard to gone through it before posting a thread.
Cooler - Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
Thermal Grease - Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G - OEM
Case fans - 3x ENERMAX T.B.VEGAS SINGLE UCTVS12P-BL 120mm Case Fan
The modular PSU has labeled at the tips PCI-E, and to get the 8 pin for the graphics card it's a 6+2, and then a 6 in the other input.
I have tried both DVI slots on the graphics card.
I have taken everything out aside from one stick of ram which is at a 1066mhz clock for the moment, as I intend to underclock the mhz of G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL11D- I purchased to fit the compatibility of my board. And I have a DVD-RW drive and a 1 terabyte harddrive, all secured.
Mainboard - GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
PSU - Rosewill HIVE Series HIVE-750 750W Continuous @40°C,80 PLUS BRONZE Certified, Modular Design, Single +12V Rail,ATX12V ...
GPU - SAPPHIRE TRI-X OC 100362-2SR Radeon R9 290 4GB 512-bit GDDR5 PCI Express 3.0 Video Card
CPU - AMD FX-8350 Black Edition Vishera 8-Core 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Desktop Processor FD8350FRHKBOX
Case -Cooler Master Elite 430 - Mid Tower Computer Case with All-Black Interior and Windowed Side Panel
Main 20 + 4 is confirmed inside, so is the 8 pin on the top right next to the CPU, the ATX12v.
I would love to get to my BIOS if I could, but I can't see anything. I reset my CMOS and everything else I was told to do but my monitor is indefinitely black, saying "NO SIGNAL"
I'm pretty sure I don't have a graphical chip set.
Then you haven't been through the checklist. I just picked one step.
