What is the average kwh for a fiber optic to coax box
kjmitchell3
How much electricity does a fiber optic system use in a building with say 200 apartments? THe power to run the system has to come from somewhere. Especially the panels that convert the fiber signal to coax. Any ideas
We're not talking about CPE here. Or an FTTH (usually GPON) network.
The OP specifically states "for a fiber optic to coax box", and expands it to be serving 200 apartments. I'm assuming that to be an optical node in an HFC network, and that the OP is asking because...
Not really. This is due to the fact that there's less signal loss in the fibre, but the electronics at either end draw a similar (or even larger) amount of power. Fibre amplifiers in particular have ridiculously powerful lasers that put off a lot of heat.
For an optical node, I wouldn't expect it to be much less than 1kW. Likely more.
That box, if it needs power, should have power requirements stated on a label, eg 5Vdc/0.5A. You can also check what adapter goes with it, but in any case it will be like 10W max.
You're thinking of a modem or ONT. This is talking about the ISP's gear that goes between the fibre and coax sections of an HFC network. Usually serves a few hundred or maybe a thousand homes.
My guess is the ISP wants to split a node to deliver better performance, and put the new node in the building's basement, dedicated to them.
Case studies of last mile networks typically had fiber pegged around 1/10th the power consumption in the datacenter. GPON is pretty decent. If you're just talking about normal point-to-point fiber Ethernet, that is not very power efficient.
My fiber ONT is 2.5Gb/s down, 1.25Gb/s up, 4 1Gb Ethernet ports and 2 POTS ports with a nominal consumption of 5 watts.
The SURFboard SB6141 172Mb down, 131Mb up with one 1Gb port has a nominal power consumption of 9 watts.
The OP specifically states "for a fiber optic to coax box", and expands it to be serving 200 apartments. I'm assuming that to be an optical node in an HFC network, and that the OP is asking because they're involved in maintaining a building and a cable company wants to put in a node in their comms room. The HFC equivalent of a fibre-backhauled DSLAM.
