I have a AMD FX 8350 CPU. I was planning to upgrade to a AMD FX 9590 however I saw it was almost impossible to keep the CPU cool so I decided to keep my AMD FX 8350. I have a stock cooler and the question I want to ask is that do I need to upgrade? My cpu at idle is about 29/30 degrees celsius and the cpu at load is about 67/69 degrees celsius at load. A problem I have is when I am using the computer sometimes my computer freezes and blue screens. The only problems that I could think of is overheating cpu or my power supply (600w) isnt supplying enough power to my pc. The software that I used to find the load of my pc is CPU-Z and I used the stress CPU option whilst checking temperatures using the Core Temp software.
PC Specs:
• CPU: AMD FX 8350
• Graphics Card: Gigabyte NVIDIA GTX 1050 2GB
• Motherboard: Gigabyte GA-990X AM3+
• RAM: 16GB DDR3
• Power Supply: Corsair CX600 80+
• Storage: 2TB HDD & 128GB SSD
• Case: NZXT S340
PC Specs:
• CPU: AMD FX 8350
• RAM: 16GB DDR3
• Case: NZXT S340
