What is the best GPU for a 240w Power supply and a HP 3048h Motherboard?
As long as you have a full length PCIE x16 slot yes they would. But I don't recommend you use a 750 Ti as it uses more power. You might get by with using one, but it would present greater risk to your power supply and the rest of your system.
Zatchsmayr
45
Cool thanks. Others have had no problem with a worse PSU than mine so yep.
