Alright, what processor cani get for 150euros and that is compatible with my motherboard. Andw hich psu would be good with that setupAre you planning to upgrade the processor?
I think your G4560 cause bottleneck to your GTX1660TI.
400/450W quality power supply will be way more than enough.
Do you want recommendation for just a psu for current system or also get recommendation for psu to the future( for 150 euros you can get a power supply for high end systems)?
And please find the cheapest psu that is good enoughtAlright, what processor cani get for 150euros and that is compatible with my motherboard. Andw hich psu would be good with that setup
Youre using a Pentium with a 1660ti? That's a major bottleneck. I would recommend at least a hextacore cpu for a 1660 Ti.I have a GTX 1660TI, Intel Pentium g4560 and my motherboard is ASUSTeK COMPUTER INC. H110M-R Rev X.0x Sorry if its the wrong one. What is the best power supply for 150 euros?
Maybe that's the next upgrade?Youre using a Pentium with a 1660ti? That's a major bottleneck. I would recommend at least a hextacore cpu for a 1660 Ti.
Could you please specify a good for around 200? The psu I got figured out thxMaybe that's the next upgrade?
Assuming your using DDR4 you could get this. Although more then likely it's slower DDR4 but at least it would be enough to do this upgrade. Then when you have the extra money get a 2x8gb DDR4 kit @3000/3200. Even at like 2133/2666 this would still be a substantial upgrade over that G4560.Could you please specify a good for around 200? The psu I got figured out thx
Ok thank you, I think I'm gonna get this.Assuming your using DDR4 you could get this. Although more then likely it's slower DDR4 but at least it would be enough to do this upgrade. Then when you have the extra money get a 2x8gb DDR4 kit @3000/3200. Even at like 2133/2666 this would still be a substantial upgrade over that G4560.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor (€118.59 @ Alza)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard (€77.80 @ Alza)
Total: €196.39
Generated by PCPartPicker 2019-11-18 22:13 CET+0100
