Question What is the max resolution on GIGABYTE Z890M AORUS DisplayPort
Jan 18, 2025
Anyone knows what kind of resolution I can get from the DisplayPort on a gigabyte z890 aorus with a intel core ultra processor?
I would like to put my three monitors in daisy chain where they all run 2560x1440@60 Hz resolution.
Intel claims the gpu can do 8K at 60 Hz and gigabyte says the DisplayPort support 2.1 and 4K at 144 Hz. My understanding is that is enough bandwidth do drive three monitors at 2560x1440 but I’m not sure.
Which processor are you looking at?
Is this the motherboard you're referring to;
https://www.gigabyte.com/Motherboard/Z890M-AORUS-ELITE-WIFI7#kf
If so, specs page says;
https://www.gigabyte.com/Motherboard/Z890M-AORUS-ELITE-WIFI7/sp#sp
Integrated Graphics Processor-Intel® HD Graphics support:
- 1 x USB4® USB Type-C® port, supporting USB4 and DisplayPort video outputs and a maximum resolution of 3840x2160@144 Hz
* Support for DisplayPort 2.1 version
- 1 x DisplayPort, supporting a maximum resolution of 3840x2160@144 Hz
- 1 x front HDMI port, supporting a maximum resolution of 1920x1080@30 Hz
* Support for HDMI 1.4 version
(Graphics specifications may vary depending on CPU support.)
Support for up to 3 displays at the same time
What are the make and models of the monitors you want to work with?
Further reading;
https://www.cablematters.com/Blog/D...lSrt9X6PTo8L8u8zqrSu76ajiKxotaSmmj4CPEyY4r9kk
You should be good to go, if your 3 monitors allow for daisychaining either off of DP 2.1 port or the USB4 port.
Moved thread from Systems section to Displays section.
