Hi,
So far I have been using 2.4 Ghz b/g/n router. Now I am planning to buy Dual Band AC Router that will also support 5 Ghz signal.
My desk in a room is about 30 - 32 feet away (straight line distance without any obstruction except door) from where I will be placing the router and currently with 2.4 band existing router Dlink 615 I have no issues in getting connected with room door closed.
However I heard that 5 Ghz has low range. One Internet site showed range as some 200 Ft amplified which I did not get (What is amplified here)
So what is the practical distance 5 Ghz signal can travel indoors with one door in between router and the client?
Any inputs would be great. Thanks.
