What is Thermal Margin, and how does it work?
Tom's made a specific post about AMD CPU/APU temps :
http://www.tomshardware.com/faq/id-2122665/understanding-temperature-amd-cpus-apus.html
The second, and trickier temperature to understand, is thermal margin. "Thermal Margin indicates how far the current operating temperature is below the
maximum operating temperature of the processor." -AMD. Further information can be found in the BIOS and Kernal Developer's Guide This temperature is based off of precise calculations that are very accurate during heavy loads. This is what you should be concerned with while stress testing your CPU. This is also the signal that is most often erroneously interpretted by 3rd party programs like HWMonitor, ect. Use AMD Overdrive to measure thermal...
maximum operating temperature of the processor." -AMD. Further information can be found in the BIOS and Kernal Developer's Guide This temperature is based off of precise calculations that are very accurate during heavy loads. This is what you should be concerned with while stress testing your CPU. This is also the signal that is most often erroneously interpretted by 3rd party programs like HWMonitor, ect. Use AMD Overdrive to measure thermal margin.
