[SOLVED] What is wrong with my Aorus X570 Elite?
Between the GPU error beeps and the scrambled display, I'd say at least one of your two cards is toast, unfortunately. Try it with just one, then the other - you'll likely find that one of them does the same thing alone, and that one will have to go (and possibly be RMA'd if you're still under warranty).
