Hoodie_ :
you need a motherboard with a socket called 1151
a BIOS update is basically when you update the instructions for your motherboard
i recommend a moterhboard with a B250 chipset for that certain CPU
hmm , okay, thanks , another question
is there a big difference between more versions of a video card?
for example : whats the difference between a 1050 TI windforce and a 1050 TI gaming ? i mean they just look different , is the cheaper/expensive version better? do they run games at different fps?
