Phenom II 720. O/c to 3.4 (16 X 215)
GA-MA78GM-S2H
G-Skill 6400
PNY 8800gt 512 O/C 700/1000
Antec EarthWatts PSU 430W
3dmark06 demo = 13350
My original build had a AMD 5000+. I just upgraded the processor to the Phenom above. I also
purchased a new monitor. 23" at 1920 X 1080, replacing a 19" 1280 X 1024 monitor. Now I can tell
the phenom is quicker that the 5000+ during comment tasks. However, playing cod4 on my old
monitor and old CPU i was maxed out with smooth framerates. Now wit my new parts, same settings
COD4 seems sluggish, especially during smoke and effects. Fallout 3 didn't run as good as I hoped. It
cant be the cpu, it only helped. It must be the 8800gt. To my understanding more memory on the gpu
helps for higher framerates. I know my mobo is praised or was for being a great HTPC with the 780g
chipset. Maybe its not good for gaming. So I was thinking about getting a 4850 but its power
requirements are 450w, and i only have 430w. lol. Ok so I went and looked at the 4870 but it
requires 2 75w 6-pin connectors. So either way i need to buy a new psu. Now my question is should i
get a new mobo or go with the new gpu and psu? Or am I missing something. Any thoughts or advice
will help.
GA-MA78GM-S2H
G-Skill 6400
will help.
