What port should i connect my monitor's audio on my Pc
UsaidYousaf
Commendable
Jul 12, 2016
116
I have an asus vg248qe and the box came with a green audio jack which ive presumed is for the monitors built in audio. Only problem is i do not know what jack to plug it into on the back of my PC.
When i plug it into the green one on the back it doesnt work and there are 5 other jacks i could use.
The colours are
green
pink
blue
orange
black
grey
I know pink is mic but where should i plug this jack into
thanks
You shouldn't, the built in speakers are crap after all. If you really want to use them for some strange reason, like colors connect, just like in every other A/V connection. In your case, green to green.
HOWEVER, if you connect it via HDMI you shouldn't need any additional cables.
