what power supply do I need for ASRock Z170 Pro4 LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
rolin2004
Commendable
Mar 24, 2016
i5-6600m? You mean the i5-6600? http://www.newegg.com/Product/Product.aspx?Item=N82E16819117562
For a desktop computer. Not a laptop, right?
If you never plan on adding a discrete gfx card, you'll be able to get by with any good quality 300W or better. The size is called ATX...
I'm buying an i5 6600m. isn't that cpu comes with graphics already so do I need to but another gpu? also when I looked at power supplies there were different types like atx or atx 12v that's when m confused thank you
If you never plan on adding a discrete gfx card, you'll be able to get by with any good quality 300W or better. The size is called ATX. Anything with ATX in the name will be the correct one for any mini tower or tower case. They are all standard size. Here is a 400W high quality PSU that will allow you to upgrade to using a discrete mid-range gfx card in the future if you feel like gaming.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%2050001669%20600479293&IsNodeId=1
Yes is a desktop thank you for that. now when it come about types when I do the search there are like 10 different types such a atx, atx 12v, eps 12v that's whe I get confused and forgive my ignorance I'm new on computers, thank you
They will all work for your system and board. But stick with the ones labeled ATX or ATX 12V. Basically, it is just a different way retailers label their product.
Looking at that motherboard, I don't think you will be wanting to live with just the built-in iGPU for very long, will you? If you plan on gaming at 1080p or better, you will want a pretty strong gfx card. More than that 400W PSU I linked to can handle. I just assumed you wanted to stay with using the iGPU alone. If you think you'll be using a discrete gfx card, let me know.
thank you for your advise. the computer I'm building is for my wife so she can work from home and all she most will be doing is remote desktop from work and some browsing
also I found this one on sale but I don't know if is compatible?
http://www.newegg.com/Product/Product.aspx?Item=9SIA2J534H0925
same for me I'm trying to load it. but I supposed is expensive but I just want to make sure my wife doesn't have any problems since she is starting to work from home you know. this is another power supply I found on sale is this one works for this set up? http://www.newegg.com/Product/Product.aspx?Item=9SIA2J534H0925
Then I will get the one that you put the link on. That was the first one that I had looked at it first. thank you for letting me know
Sorry, replying to a message that was sent a year ago but I've been looking at old posts to try and figure out an answer.
What power supply would you reccommend for this build:
ASRock Fatal1ty B250 Gaming K4 LGA 1151 ATX Motherboard
GeForce GTX 1060 OC 6GB Video Card
i7 7700 Quad Core LGA 1151 3.6 GHz CPU
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3000MHz
Sorry thats a lot of stuff, don't know what is and isn't necessary but any help or suggestions would be greatly appreciated!!
I'm surprised one of the mods hasn't taken this necro thread down yet...lol. But to answer your question, the smallest recommended by Nvidia is 450W. However, I would not recommend going that small. It doesn't look like you'll be doing any OC'ing since you didn't get the i7-7700K, but you should look for something 500 -550W or better.
This is a good PSU if you want a suggestion for a low cost, high quality unit. But check out the other Seasonic units if that one doesn't appeal to you.
