What Power Supply Do I Need?
VeryWell
19
hello there. I built a pc and couldnt find any powersupplies. What do you guys recommend? (it needs to be in amazon)
my pc is;
gpu : ASUS GeForce GTX 1070 8GB ROG STRIX OC Edition
ram:ADATA XPG Z1 DDR4 2400MHz (PC4 19200) 16GB (8GBx2) Memory Modules
the motherboard:ASUS LGA2011-v3 5-Way Optimization SafeSlot X99 ATX Motherboard X99-DELUXE II
coolers; Thermaltake Riing 14 RGB Series High Pressure 140mm Circular LED Ring Case Radiator Fan CL-F043-PL14SW-B
Thermaltake NiC C5 120mm Untouchable CPU Cooler CLP0608
harddrive:WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch Desktop Hard Drive (WD10EZEX)
SSD (2x): XPG by ADATA SX930 120GB 2.5 Inch SATA III Extrem Performance Read up to 560MB/s Gaming Solid State Drive (ASX930SS3-120GM-C)
Processor: Intel Core i7 6700K 4.00 GHz Unlocked Quad Core Skylake Desktop Processor, Socket LGA 1151 [BX80662I76700K]
and the case; AeroCool Black Case (DS230)
Thanks and I Hope you Have a good day.
Ok, that monitor justifies upping GPU to 1080 for getting comfortable 144 hz in every game. Also, increased SSD size because bigger size=better performance for SSD. Added that Aerocool case.
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor ($329.89 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($34.89 @ OutletPC)
Motherboard: Asus - MAXIMUS IX HERO ATX LGA1151 Motherboard ($215.99 @ SuperBiiz)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory ($159.99 @ Newegg)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive ($247.99 @ B&H)
Storage:...
Hi - Once you change either your Mobo or CPU (as mentioned above by DRagor) a good quality
500- 550w PSU will be more than enough for that build. Some to choose from:
https://pcpartpicker.com/product/TgW9TW/seasonic-power-supply-m12ii520bronze
least expensive modular good quality unit
https://pcpartpicker.com/product/hWs8TW/evga-b3-550w-80-bronze-certified-fully-modular-atx-power-supply-220-b3-0550-v1
Bothe above - Bronze efficiency
https://pcpartpicker.com/product/kz7CmG/evga-power-supply-210gq0650 - Gold efficiency - Modular
https://pcpartpicker.com/product/kz7CmG/evga-power-supply-210gq0650 - Gold efficiency - odular
https://pcpartpicker.com/product/DPCwrH/seasonic-power-supply-ssr550rm - Gold efficiency - modular
thanks for the response, but what do I need to change the cpu or the motherboard to?
What uses for the machine? Why you have chosen such expensive motherboard in first place - any particular reason or just looking for good quality stuff?
I just saw this on youtube. I need the pc for gaming and editing only. thank you for the answer, but may I ask, what are the parts that I need to change?
Have you used PCPartPicker to test compatibility?
This what I would suggest:
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive ($127.99 @ B&H)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.33 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8GB Video Card ($429.98 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($88.99 @ SuperBiiz)
Total: $1436.05
Generated by PCPartPicker 2017-05-19 06:55 EDT-0400
Case is personal thing, just checked if the one you chosen is big enough, and it is for those components.
thank you so much. you helped me really good.
I would want a lot, but I have a limit of 2000 dollars. can you ramp it up a bit pretty please? Thank you.
Hi - Just add your case:
https://pcpartpicker.com/list/T6rYYr
it says "The motherboard M.2 slot #0 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6Gb/s port is disabled"
also, can you do it around 2000$?
Hi again:
https://pcpartpicker.com/list/sjJmpb
Sums to $1870, but several of the prices don't include shipping, so you
will be close to 2k. Also, please look at the case I added. Cases are very personal, so you may want to select
a different model. The case I chose is good quality & know to be quiet.
It is a common practice for the M2 slot to share power with a sata connection & one to be disabled if the
other is in use. You still have plenty of connections for your internal components.
the case can be anything if its quiet and red/black.
Not as quiet as the one linked above(solid black) - but these have the red/black you're
looking for:
https://pcpartpicker.com/product/Rz2kcf/corsair-case-cc9011036ww
https://pcpartpicker.com/product/pL6BD3/raidmax-case-atx502wbr
https://pcpartpicker.com/product/CN8Zxr/enermax-case-eca3280abr
https://pcpartpicker.com/product/n2qdnQ/aerocool-case-xpredatorx3devilrededition
the aerocool xpredator one seems perfect.
Video Card: Gigabyte - GeForce GTX 1080 8GB AORUS xtreme edition Video Card ($559.99 @ Amazon)
Case: Aerocool - Xpredator-X3 Devil Red Edition ATX Mid Tower Case ($103.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ B&H)
Total: $1801.05
Generated by PCPartPicker 2017-05-20 07:33 EDT-0400
That's what I think would be optimal build. If you would still have spare cash, I would buy another monitor (something basic 24 inch 1080p 144 hz) so you can have another display for open browsers while gaming on main monitor.
1 dollar is 3.55 turkish liras. so the windows costs 355 turkish liras but I already have one on my flashdrive.
