S silva_4 Prominent May 16, 2017 3 0 510 May 16, 2017 #1 Hello all, may I ask what PSU sould I chose, my rig has I5-2320 VGA r7-360 hdd wd blue 1tb,,,, Thanks before for your answer
Solution R R Rexper May 16, 2017 Budget and region? Otherwise an EVGA G2/G3, Corsair RMx, or Bitfenix Whisper M.
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 May 16, 2017 #2 The 550 watts XFX will work very well and is highly rated - https://www.amazon.com/XFX-ATX12V-EPS12V-Supply-P1-650G-TS3X/dp/B00I64OYM2 Check for prices at Newegg and at other retailers. Upvote 0 Downvote
4745454b Retired Mod Apr 29, 2006 29,244 449 93,590 May 16, 2017 #3 Because your system is so lowend, a 400-500W would be a better choice. Just make sure it's a quality unit. If you buy it for $20, it isn't a quality unit. Upvote 0 Downvote
R Rexper Respectable BANNED Apr 12, 2017 2,131 2 2,510 May 16, 2017 Solution #4 Budget and region? Otherwise an EVGA G2/G3, Corsair RMx, or Bitfenix Whisper M. Upvote -1 Downvote Solution
