Question What power supply should i get?
Aug 19, 2019
9
so im building this computer right here https://ca.pcpartpicker.com/list/jv6Tvn
I keep changing my mind on some stuff like the Power supply. ive heard some bad reviews on the one I have in right now. ive heard good stuff about this one though.
https://www.amazon.ca/dp/B01B72W0A2/ref=twister_B074V4XK8T?_encoding=UTF8&th=1
I cant make up my mind. my budget at this point is 50-100$ I do not not know if 550W is enough or if I need 650W? also if you see anything else in the computer I should change just tell me:) my budget is around 1500$ Canadian.
WildCard999
Herald
I would change it to a Seasonic Focus Gold 650W, good quality unit with 7 year warranty and plenty of power for the build. I also changed to SSD as it is faster and slightly more storage for cheaper. I also recommend changing the motherboard unless you know that Gigabyte has been updated to support the 3rd Gen. Some of MSI's boards such as the Tomahawk allow you to update the BIOS without a CPU which is why I put that into your build. These changes put you right at the $1500 mark.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($265.50 @ Vuugo)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard ($149.99 @ Memory Express)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory ($102.99 @ PC-Canada)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive ($74.99 @ Amazon Canada)
Video Card: XFX Radeon RX 5700 XT 8 GB Video Card ($519.99 @ Memory Express)
Case: Corsair Carbide Series 275R ATX Mid Tower Case ($69.99 @ Corsair)
Power Supply: SeaSonic FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($117.50 @ Vuugo)
Monitor: Asus VG245H 24.0" 1920x1080 75 Hz Monitor ($199.99 @ Amazon Canada)
Total: $1500.94
Generated by PCPartPicker 2019-08-22 09:19 EDT-0400
View: https://www.youtube.com/watch?v=iTkXunUAriE
Aug 19, 2019
9
Total: $1500.94
stupid question but I can never tell, does that total include tax or no? and thanks for your input :)
Aug 19, 2019
9
Total: $1500.94
thanks again for the help! another question this time about the motherboard. I cant figure it out 100% it looks like it only has one plug in for the fan? is this true?
